hello everyone my bikes a sachs roadster with a yamaha virgo 125 cc twin v. i am haveing a problem with starting the bike things i ave done
check plugs for spark
remove carb and fully cleaned
check all pipes or hole rips
put new plugs in
then i fitted it all back together got the bike to tick over a little bit but no revs then i notice it was only the rear engine working .so i removed front engine spark plug no fuel getting into it so i removed rocker cover to make the valves was working and there loads off compression so i put that back together then try to start again but nowt again can anyone help me .
does any1 no wheres best place to get parts from thanks again andrew
Welcome andrew, best post in workshop mate, as there posts are buried quick, due to lots of new members,, ,, take the float bowl of the offendind carb,,, and see if fuel running in,, ,, then choke jet, then pilot jet,,, elimination dear Watson,,,, :grin:
no shit sherlock! :spin2:
