Posted October 31, 201114 yr Hi everyone, it's my first time using a forum. Recently bought a fzs 600 fazer 1998. I'm not that clued up on motorbikes so I apologies in advance if I write or ask a daft question. I'm having a problem with 3rd to 6th gear between 6 and 7000 rpm. When I'm in 3rd gear I can feather through 6 and 7000 rpm but the bike splutters and then seems to pull through. The higher the gear the worse it seems to be. From 6000 rpm when I full throttle 6th gear struggles to get past 7000 rpm at all. When the bike is in neutral the revs can be cranked up to high revs. no problem. Work that I have carried out on bike recently, as follows: New aftermarket downpipes, oil filter, oil, spark plugs, spark plug caps, fuel filter, fuel cleaner,air filter, new carb inlet rubbers. Work carried out on bike recently by bike mechanic, as follows: Chain and sprockets, carb's stripped / cleaned and reset. CDI unit changed over. Mechanic said the jets are clean and in mint condition. The latest thing that I have tried is fitting an original set of dwonpipes to see if that would help. It didnt. Any help would be greatly appreciated, this is starting to do my head in. Many Thanks
October 31, 201114 yr A few thoughts (in descending order of probability): Leaky carb diaphragms Main jets blocked Ignition timing out Valve timing out Other than that - buggered if I know!
October 31, 201114 yr Yip adamski" when fitting aftermarket pipes or air filtres, The jets will need attention, A dyno jet. kit or something , ,,, float levels are important when at wide open throttle ,
October 31, 201114 yr Author Thanks for the advice KirriePete and once again blackhat250. I'll pass this information on and see where it gets me. Fingers crossed, i'll keep you posted of any progress. Cheers
November 6, 201113 yr Author Hi Evereyone, Took my bike to the local dynojet on Saturday morning. The problem was being caused by my aftermarket delkevic downpipes. The jets had to drop down 6 sizes from 115 to 100. The carbs also got balanced. Wish I had went here in the first place as it would have saved me a couple hundred quid. Bike is running like a dream. Thanks for all the advice, it was appreciated. Cheers
