Posted October 19, 201114 yr Hi everyone,i have a small problem with my 2001 dt125r, when i use the front brake the front end dives quite a lot, i have changed the fork oil but it has made no difference so do i need new springs or is there something else i should be looking for? thanks, Richy
October 19, 201114 yr Moderator Its normal for an off road type bike to dive like a profesional footballer under braking, unless you hear a clonking noise indicating either hitting the bump stop or a broken spring there is nothing wrong. Stop riding it like a race bike and learn to balance the braking between the front and rear brakes, the front disk on DT's is shite anyway and fades like cheap jeans so consistent hard braking is not reccomended, you will go through pads and even disks very quickly otherwise.
