Posted October 16, 201114 yr Hi All I have just taken off the swinging arm to replace the bushes (mot Failure) where can I get them ? I need the bush that ties the arm with the mono shock. Any ideas? Cheers Geo
October 16, 201114 yr This should give a better idea of what you need Geo http://images.cmsnl....760d-4_3bdf.gif http://www.cmsnl.com/yamaha-dt175g-dual-purpose-1980_model8733/partslist/D-04.html
October 16, 201114 yr Author I don;t think so its the bush from the suspension arm fixing on to the swinging arm frame.
October 16, 201114 yr Here? http://images.cmsnl.com/img/partslists/rear-shocks-dt175g-dual-purpose-1980_bigyau0760d-6_6365.gif http://www.cmsnl.com/yamaha-dt175g-dual-purpose-1980_model8733/partslist/D-06.html
October 16, 201114 yr Moderator you need to take care here, I think the early one is wider than the later one
October 16, 201114 yr Author Yep its there Number 9" lower bushing" Nice parts site. Any idea where I could get the bush though?
October 16, 201114 yr Yep its there Number 9" lower bushing" Nice parts site. Any idea where I could get the bush though? Them Geo cmsnl.com
October 16, 201114 yr Them Geo cmsnl.com The good thing about them is, that when you click on part link, it shows other compatable bikes for same part, on top rightt of page.
October 16, 201114 yr Moderator there are part manual in the workshop forum, it would benefit you you to use them Geo
October 16, 201114 yr Author Cheers chaps They haven't got he part but they certainly are comprehensive. II have trawled through yam bits and wemoto no joy should I try a bush manufacture company?
October 16, 201114 yr If Yambits or Yuniparts don't have them try your local Yamaha Dealer. I am restoring a DT125MX and you will be surprised how many bits are still available.
October 21, 201114 yr Author Yamaha hunted 1 down so will be fitting tomorrow that s 1 more thing sorted Thanks again Geo
