ty50mx engine raceing reeds oil feed pump settings
Hi All
have had my reeds fracture so brought the only reeds the local shop had. these are boydon raceing reeds,(looks like they have had these sitting around for a while) does anyone know how much these change the engine with regard to the oil delivery system.
( i take it with the more petrol going in the more oil it will need) the carb has already been up jetted in the past + filter , dont want it for speed , just to keep her running for work ( engine ty50mx 1980 fitted in dt50mx frame and running gear). cheers nigel
thanks oldgitonabike just wanted to make sure before i put them in. have some blue medium strenght loctite somewhere in the shed. cheers nigel
