October 9, 201114 yr Has anyone fitted a rev counter to their XVS650? I read on here that at 100kph the 650 is doing 4,000 revs in top gear. Can anyone tell me what revs the bike would be running at 50kph in 3rd and 4th?. With the rumbling and growling from the transmission, it's hard to tell whether the engine is staggering, or pulling freely. It does seem to pull away in top from 50kph ( 2,000 rpm? ) smoothly, without any hesitation.
October 9, 201114 yr I don't have a tachometer attached to my draggie (wish I did!), but my experience is you're better off in 4th pulling away at 50kph (about 30mph), especially if you're in a hurry. 5th works fine (unless you're going uphill) but you do get quite a bit of clattering from the transmission. Cruising at 50kph in 5th is fine.
October 10, 201114 yr My general upshift points, bearing in mind I have custom pipes fitted: 1st - 0mph 2nd - 20mph 3rd - 30mph 4th - 40-50mph 5th - 60mph and above. I have no idea what the KPH is and I refuse to work in such measures, because I'm stubborn I tend to keep revs down teh lower end of the powerband and ride that. It uses a touch more fuel but everything is just so much easier.
