October 3, 201114 yr Anyone out there used a sena bluetooth headset unit with an open face helmet. I hear they work fantastic with full/flip helmets,but not heard much from open face helmet users.
October 4, 201114 yr I've used a Scala Rider headset on an open-face before. Make sure your mic has noise attenuation and all that gubbins, else the wind noise means your transmissions will be nothing but the sound of someone blowing into the mic. That will seriously piss your fellow riders off after 200 miles of this!! TBH, most bluetooths 'work' fine... the problem usually exists between helmet and head. There's teh mic issue mentioned above. Also, unless you have a decent seal around your ear and the speaker, the wind gets in and wrecks your chance of hearing anything clearly. Money down the drain if you don't look to this part first! Other than that, they're usually just as good as a closed face.
October 14, 201114 yr Author Yeah I don't won't out lay my cold hard cash for nothing. Have only been able to find afew comments on forums in regards to open face helmet coms,just have to keep searching before I hand over the cash ah. None of my riding bubbies have any coms to try. Thanks Ttrackmaster
