Seca 750 blinkers
I have a 1982 Yamaha XJ750 Seca. The turn signals light up, both front and rear, but don't flash. Sometimes at higher speeds they will flash but rarely. Any ideas?
welcome to the YOC
first thought would be to introduce yourself first then maybe someone may answer your woes
Dave
  • 7 months later...
There's a flasher relay located underneath the tank. You might want to check if it needs replacing...
Hi dgregerson, Welcome to the YOC, might be nice if you did and intro BEFORE rocking up and asking questons of strangers. I have an 82 XJ and can tell you all about where the relay is and how to fix your problem but INTRO first please. :jossun:
