October 1, 201114 yr I have a 1982 Yamaha XJ750 Seca. The turn signals light up, both front and rear, but don't flash. Sometimes at higher speeds they will flash but rarely. Any ideas?
October 2, 201114 yr welcome to the YOC first thought would be to introduce yourself first then maybe someone may answer your woes Dave
May 7, 201213 yr There's a flasher relay located underneath the tank. You might want to check if it needs replacing...
May 8, 201213 yr Hi dgregerson, Welcome to the YOC, might be nice if you did and intro BEFORE rocking up and asking questons of strangers. I have an 82 XJ and can tell you all about where the relay is and how to fix your problem but INTRO first please.
