September 27, 201114 yr as above realy i want to fit a rev counter drive to a dtr but can only find 1 for a tdr125 are these the same?? thanks
September 27, 201114 yr Author no the actual drive bit in the enginge as ask a dealer i will but was hoping to find out tonight so i can order the part thanks all the same
September 27, 201114 yr Moderator why dont you just order one for a dtr? i dont understand... I used to be able to find part numbers but can no longer do so because the website has disappeared so i'm stuffed now !
September 27, 201114 yr Author theres 1 on ebay for a dtr but it hasnt got the shaft/pin that gose thro the middle that holds it in place but the tdr 1 on there has got it all hence the question i mean they look the ect both on the gears and the engine casses look the same but im not sure thanks again
September 27, 201114 yr Moderator i would be very surprised if they are different, try talking to the seller ...see if he would accept returns...the motors are similar though
September 27, 201114 yr Author he dose accept returns no probs but he dosnt no if there the same thanks
September 27, 201114 yr Moderator well if he's aware of the situation you will be able to return it if you pay the return postage, just make sure thats OK with him first, theres a good chance it will be the same though...
