Posted September 19, 201114 yr Hi all, Help needed please with the wireing route on my 1978 XS, as you can see, i've started the rebuild approx 6 months ago, just haven't had the time to do more. I am now stuck on the correct route of the wireing loom,can any one give the right route (left/right, over/under the frame), either words and /or with pictures would be great help. I have started from the back, tail light,fuse box ect. graham just put new clutch plates in, and re-zinc plated the kick shaft. I've spent about grand on the motor alone.
September 19, 201114 yr Moderator always take pictures when rebuilding any bike, it realy helps! When I get home and remember, I have the yam routing diagram which I will need to scan in.
September 19, 201114 yr Author Hi Drew, thanks. I know, take more than you think you need. I just need the route of the wire, the connection are straight forward, !!! graham
September 20, 201114 yr Author Thanks drew, u's the man, what would we all do with out you. I've never seen a wiring diagram like this, it's not in the 3 workshop manuals I have. where's it from. by the way, you've done a excellent job with the flat tracker, been following your brog. thanks once again, very much appreciated. graham
