Hi all,
Help needed please with the wireing route on my 1978 XS, as you can see, i've started the rebuild approx 6 months ago, just haven't had the time to do more.
I am now stuck on the correct route of the wireing loom,can any one give the right route (left/right, over/under the frame), either words and /or with pictures would be great help.
I have started from the back, tail light,fuse box ect.
graham
just put new clutch plates in, and re-zinc plated the kick shaft.
I've spent about grand on the motor alone.
always take pictures when rebuilding any bike, it realy helps!
When I get home and remember, I have the yam routing diagram which I will need to scan in.
Hi Drew, :D thanks.
I know, take more than you think you need.
I just need the route of the wire, the connection are straight forward, !!!
graham
Thanks drew, u's the man, what would we all do with out you.
I've never seen a wiring diagram like this, it's not in the 3 workshop manuals I have.
where's it from.
by the way, you've done a excellent job with the flat tracker, been following your brog.
thanks once again, very much appreciated.
graham
  • 3 months later...
