September 17, 201114 yr I run my bike out of fuel and can't get it running again. I've cleaned out the air filter and what I presume is the fuel filter, checked the needles in the carb and flushed it through with fresh fuel and cleaned out the fuel tank. Had it running a few times but had to keep the revs up for it to stay running and it won't start at all now. I'm all out of ideas now and was wondering if anyone had any ideas of what it could be? Thanks in advance Oliver
September 17, 201114 yr Moderator Does it have a vacuum operated fuel tap with a PRIME (PRI) position Olliver? if so you must use this position after running it dry, then you can swith back to ON
September 20, 201114 yr Author no. its gravity fed straight into the carb. ive got it running but when it tries to idle/ gets to low revs fuel comes out the overflow pipe off the carb. i'm thinking the float in the carb may not be returning propperly to shut the fuel off.......but when taken apart it seems to spring down freely......any ideas?
September 20, 201114 yr If fuel's pi$$ing out of the overflow, no wonder the poor thing won't run properly. Check your float height is set correctly, then check that the float's not got a leak (air out, fuel in, float sinks), then check the float needle & seat for crap/wear. One (or more) of these things will be the cause, sort it and you should be OK. HTH
September 20, 201114 yr Moderator Hmmm have you had the floats out and put them back upside down i wonder
September 21, 201114 yr Author Had the float out and it was correct and intact (18.9mm fyi). Double checked all the jets and needle for wear, had the sleeves out, all washed in fresh petrol, and tighten up correctly, re-fitted, started after 2nd turn over, ran fine whilst warming up, then it started spitting petrol out of the carb again, promptly cutting out! every single part of the fuel system has been cleaned and double checked from the tank to the carb/inlet manifold.......floats not upside down! didn't touch the idle screw as was working perfectly before, (But are you ment to re-calibrate it every time you take the carb apart????) hmmm....i'm led to believe that it HAS to be something to do with the float and too much fuel getting in, but cant visible see anything wrong with it........what other problems could cause this? Ollie
September 21, 201114 yr Moderator ...hmm a compression test would be good might be worth checking the valve clearance on the inlet valve and a visual inspection of the top spring retainer and collets are in place.
September 28, 201114 yr Author haha! all good! dont know i missed it but found a tiny stone in needle jet! and how it got there is even more worrying! ph well, every cloud etc is that its running sweet as a nut after fresh oil and a clean up!! thanks guys
