2001 yamaha sr 125 valve clearances
Hi,
i wounder if someone tell me the correct order to reset the valve clearances on my 2001(y) yamaha sr 125
is it set timing marks to top dead center and adjust both valves ?
thanks for anyone who can help me
You will need the manual for the bike.
Different bikes have different order's,,,,,,eg. start at piston number X
Drop the oil, take off crankcase cover,,, prob be markes stamped on it to align TDC,,,,rotate with a spanner
its usually intake valve first,,,,,always dont on compression stroke.
Not an easy job if you've never seen it done before. If in dout have a garage do it for ya !
Best of luck.
Welcome to the YOC :patty:
Seem to remember the early SR125 had two inspection plugs you undone with a large flat screwdriver on the LH crankcase cover so you didn,t have to remove the whole cover. Not sure if the later ones were the same. You should then be able to turn the engine over with a socket while looking for the TDC mark. As 2Wheels has said the valve clearances must be done at TDC on the compression stroke with both valves closed.
