January 17, 200520 yr Hi, bit of an odd one this, as I think that the TRX has started to make a weird ticking noise at tick-over, hard to say with the load-ish pipes. Has anyone else had a similar problem, I think it could be the cam-chain rattling, it's unlikely to be top end (valves) as these were sorted (at great expense) less than 10,000 miles ago. Any advice, info would be great. Thanks Chris
January 19, 200520 yr Hi, bit of an odd one this, as I think that the TRX has started to make a weird ticking noise at tick-over, hard to say with the load-ish pipes. Has anyone else had a similar problem, I think it could be the cam-chain rattling, it's unlikely to be top end (valves) as these were sorted (at great expense) less than 10,000 miles ago. Any advice, info would be great. Thanks Chris I had a similar thing with my fz making rattly noises all through th rev range though , after much ballache i found that the exhaust downpipe gaskets had perishd replaced them and rattling went . just a thought
January 19, 200520 yr Moderator I hate the simplist probs because i never find them until ive tried every thing possible!
