Hi guys, i started a topic about this before, but im not sure i completely explained what i wanted :o
Ive got an xj600 95 plate, and i want to raise the back end to make it look more of a streetfighter. Only problem is, i cant find any kits to achieve this, is there another shock from a different bike that i could use? or does someone know another way?
Cheers in advance
  • 3 weeks later...
If the suspension uses "dog bones" to adjust the ride height, get some longer ones made? I'm sure they must be available from somewhere? Otherwise, I wouldn't know, really. I assume you've trawled the web?
Its Shorter Dog Bones you want not longer, very easy to make you can buy the flat bar from B&Q. Just shorten by 10mm will raise the back a lot.
Adam.
Adam.
D'oh. Yes, shorter, of course... :crazy:
If I remember correctly, it's not on dog bones (at least mine wasn't). The shock just went straight from the frame to the swingarm. I used to have a list of shock lengths / eye sizes. I'll see if I can find it and post it on here.
  • 2 years later...
I don't mean to jack this thread to send you to another forum, but you can find all that info on XJRider.com. there are several other shocks that swap in, and a few that will raise the rear. Plus, there's several projects where people have rebuilt the rear subframe to make it more street-fighter height.
Sorry mate but LOOK AT THE DATE 2011 pretty sure the subject is well sorted by now!
This topic is now closed to further replies.
