re xt660 bad clunk more detail
hi did not expect response so quick thanks
i have change front and rear wheel bearings /seals/ brake pads/cush drives/bearing and seal in sprocket carrier and tyres as per normal service oil change adjusted clutch bottom of cable and top
the free play is with the bike in gear and rear wheel off the ground with the chain adjusted as per spec
when you turn the rear wheel back and forward there is about on link on the chain of movement before the wheel locks up the small sprocket is tight on the shaft as the lock nut and shaft move at the same time so the free play seems to be internal i am on holiday from monday so might not have time to strip it for a week
ps i i pull the clutch in then put in gear it gives out a loud thud but if i hold the clutch in for 10 secs
then put in gear it is quiet i is not clutch drag but in the 10 secs it seems to take up the free play
it can also be rough when riding
thanks again
And your question is ??
Sounds normal enough to me !!!
