YZF750R Float Height
Ok guys anyone know what the correct Height is for the Floats on a 95 YZF750R, when measured from the float Chamber Gasket surface??
The only data I have doesn't actually list float height only fuel level which is listed as 6.8 - 7.8mm above the lines marked on the bottom of the float chamber by attaching a piece of clear hose to the drain hose union on the bottom of the float chamber and undoing the drain screw and holding the hose vertical by the lines.
