August 16, 201114 yr Hi all, I have been restoring the above over 10 years or so and now have a working..cough..bike. The only problem I have is that the bike runs fine on start up ..but if you put the choke in..it dies..instantly..the throttle is completely non-responsive. I am not a mechanic by any means, but I thought this may be fuel crystalised in the carb..if so, what do i use to clean it? Any ideas? Many thanks
August 16, 201114 yr Hi welcome to the YOC but you might want to read this post first in the new members section Then pop along to the index and at the very top is the new members section...
August 16, 201114 yr Hi there " the pilot jet will be clogged, strip carb,, either ultra-sonic cleaner , or take out jets,, carb cleaner is also in spray cans,,,
August 16, 201114 yr Author Hi there " the pilot jet will be clogged, strip carb,, either ultra-sonic cleaner , or take out jets,, carb cleaner is also in spray cans,,, Great thanks for the quickie! I know it may seem rude to post "how can I fix" on my first post..but my hands were all greasy and i was in mid meltdown over this problem Thx..I'll give it a go
