February 13, 201214 yr Author Had the MOT today, went through. However, the only problem was the swinging arm nut was loose and needed to be tightened up. I tightened it up of course when I replaced the whole at lot at Christmas: a few weeks ago. So I was a bit surprised to see it had shaken loose . On closer inspection the blue nyloc bit had broken away, so it wasn't doing its job. I'll need to replace it. Its a 17mm socket job. I can of course take it off but its raining hard outside and I'm not going out to the shed!! So in the comfort of a warm house......... Is it M10 or 12 ? and I suspect its metric fine pitch 1.25...............looks like i'll be going to in the morning! to get a new one! I'm sure Paul knows what size it is!
February 13, 201214 yr Moderator original number is 90185-12046...so thats an m12 NEO but I dont know the pitch
February 13, 201214 yr Author I knew you'd know! Thats incredible you know the breakdown of what the yamaha codes mean, i knew they must mean something but...wow!....... you're the man! I've just been looking at the codes.........so 06 are M6 and 08 are M8's.......simple when you know. I bet it is a metric fine, because genuine ones are expensive for a nut! and metric fine always seem to be more expensive than regular nuts! nuts oooooh hazel nuts! OOOHH Cadbury take them and they make 'em in to chocolate. Who remembers that?
February 13, 201214 yr Moderator ,,,,,,nuts oooooh hazel nuts! OOOHH Cadbury take them and they make 'em in to chocolate. Who remembers that? sure do mate, it's the recent stuff i forget
