Had the MOT today, went through.
However, the only problem was the swinging arm nut was loose and needed to be tightened up.
I tightened it up of course when I replaced the whole at lot at Christmas: a few weeks ago.
So I was a bit surprised to see it had shaken loose
On closer inspection the blue nyloc bit had broken away, so it wasn't doing its job. I'll need to replace it.
Its a 17mm socket job.
I can of course take it off but its raining hard outside and I'm not going out to the shed!!
So in the comfort of a warm house.........
Is it M10 or 12 ?
and I suspect its metric fine pitch 1.25...............looks like i'll be going to in the morning!
to get a new one!
I'm sure Paul knows what size it is!
I knew you'd know!
Thats incredible you know the breakdown of what the yamaha codes mean, i knew they must mean something but...wow!....... you're the man! :hail:
I've just been looking at the codes.........so 06 are M6 and 08 are M8's.......simple when you know.
I bet it is a metric fine, because genuine ones are expensive for a nut! and metric fine always seem to be more expensive than regular nuts!
nuts oooooh hazel nuts! OOOHH Cadbury take them and they make 'em in to chocolate.
Who remembers that?
