Wont rev over 10k
Hi, can't get my yzf750 to rev over 10k even when slipping the clutch it goes upto the amount it slipped to and stops, feels like it has a flat spot about 7k in high gears, air filter is clean plugs are new, if is cold about 5c, it won't rev over 7k
Any help appreciated
I will, but I though that it caused problems about 4000 rpm if it wasn't working ? Not high end revs
Right, the exup valve doesn't move when the ignition is switched on but moves when the engine is reved, it's a 1994 bike if it makes a difference
