Hi, can't get my yzf750 to rev over 10k even when slipping the clutch it goes upto the amount it slipped to and stops, feels like it has a flat spot about 7k in high gears, air filter is clean plugs are new, if is cold about 5c, it won't rev over 7k
Any help appreciated
I will, but I though that it caused problems about 4000 rpm if it wasn't working ? Not high end revs
Right, the exup valve doesn't move when the ignition is switched on but moves when the engine is reved, it's a 1994 bike if it makes a difference
