Posted August 1, 201114 yr Hi all, I was out on my first proper long ride at the weekend, which was great (even though it was pissing down). However when ever I got the about 50 MPH my right wing mirror would slowly tilt forward so I had to keep re-adjusting it. Got a bit annoying after a while. Does anyone know how to fix this? or do I need a new wing mirror? Thanks
August 2, 201114 yr Hi all, I was out on my first proper long ride at the weekend, which was great (even though it was pissing down). However when ever I got the about 50 MPH my right wing mirror would slowly tilt forward so I had to keep re-adjusting it. Got a bit annoying after a while. Does anyone know how to fix this? or do I need a new wing mirror? Thanks is it moving on the ball joint or is the nut securing the mirror head not tight enough?
August 2, 201114 yr Author Well the arm stays still. Its just the mirror itself that moves on the ball. Can this be tightened?
August 2, 201114 yr Hi mate, yes sounds like your mirror is loose, just under the mirror there should be a nut, possition your mirror to where you want it then tighten the nut up, = job... jobbed
August 2, 201114 yr Author Hi mate, yes sounds like your mirror is loose, just under the mirror there should be a nut, possition your mirror to where you want it then tighten the nut up, = job... jobbed Cheers, I will give that a try. Thanks
August 2, 201114 yr try this iff that don't work, pop the glass out , it may or may not have a rubber suround that peales off,(mine does) at the back of the glass should be a nut , tighten it , only a bit ,because it has a plasic cup that easily splits, put the glass back and bobs your aunt fanny.good luck.
