Kfc1404 Posted July 30, 2011 Posted July 30, 2011 Hi All, I have an o2 sensor eliminator fitted at present on my XVS1300 Midnight Star and I am about to fit Cobra Fi2000, do I need to remove the eliminator? Also if I fit a Baron Big Air Box with the Cobra, do I need to do anything with the carburation? and what about the eliminator? Yours confused Graham
clarke Posted July 30, 2011 Posted July 30, 2011 Hi Graham, I believe you can run the O2 mod, the Cobra FI and the Baron with no problems whatsoever. Midnight61 is better placed to suggest a setup on the Cobra Good luck. Graham
Kfc1404 Posted July 31, 2011 Author Posted July 31, 2011 Hi Graham, I believe you can run the O2 mod, the Cobra FI and the Baron with no problems whatsoever. Midnight61 is better placed to suggest a setup on the Cobra Good luck. Graham Many thanks!
midnight61 Posted August 2, 2011 Posted August 2, 2011 hi, as i see it, by all means keep the 02 eliminator on the bike, as long as you run the cobra fuel processor 'closed loop' as i do... the O2 eliminator will be totally ineffective if you run it 'open loop' My set is very differemnt to yours, im running Cobra speedster shorts, cobra 'closed loop' fi, standard 02 sensor. k and n air filter and a drilled airbox...my cobra fi settings are factory settings .1.3.1, i never felt the need to alter them, it runs fine and returns over 50mpg according to cobra, even with a BAK on the bike 1.3.1 should be good, although, all bikes are different and you may feel the need to adjust the cobra fi...or better still, once you've got it all installed, treat her to a dyno run to dial the fuelling in that way
