July 28, 201114 yr Hi, I have just registered here and just bought an XJ6 FA after being away from biking for...nearly 20 years! Great bike to get back on, loving it! My problem is putting air in my tyres!, should be simple? I went to my local petrol station and although the nozzle of their air pump is angled I had real trouble getting past the brake discs and the cast arms on the wheels to put air in. Am I missing something? Or do I really have to buy my own? Any help would be appreciated. Stefan
July 29, 201114 yr Moderator yeah I have the same problem with my bandit, now i pump them up at home with a footpump or one of the car pumps that plug into a lighter socket.
July 29, 201114 yr Moderator I use a pushbike pump, seriously. Not the oldy world thing you used to find on the cross bar but a propper 2 handed high volume plunger job. You know one looks like an old fasioned dynamite plunger from the cartoons. Anyway its designed for mountain bikes and goes up to 80psi, use it for the car, caravan, bike everything that needs air. They are about 30quid in halfo#ds. Makes bike tyres easy, esp as they should be done cold.
July 29, 201114 yr i recommend not bothering with the bent valves as they dont work very well left me stranded with no air most bike dealers will beable to get hold of a tube or a valve that is bent in the factory
July 29, 201114 yr Moderator I use a pushbike pump, seriously. Not the oldy world thing you used to find on the cross bar but a propper 2 handed high volume plunger job. You know one looks like an old fasioned dynamite plunger from the cartoons. Anyway its designed for mountain bikes and goes up to 80psi, use it for the car, caravan, bike everything that needs air. They are about 30quid in halfo#ds. Makes bike tyres easy, esp as they should be done cold. I do too cynic, i said a foot pup but in reality i use one 'o' them They are know as 'Track pump'
