Im thinkin of part exchanging my 2004 yamaha aerox100 for a piaggio typhoon125 2011 below is the link yea or nah?
http://www.bikez.com/pictures/large.php ... iaggio.jpg
General information
Model: Piaggio Typhoon 125
Year: 2011
Category: Scooter
Rating: 75.3 out of 100. Show full rating and compare with other bikes
Engine and transmission
Displacement: 125.00 ccm (7.63 cubic inches)
Engine type: Single cylinder, four-stroke
Fuel system: Carburettor
Cooling system: Air
Gearbox: Automatic
Transmission type,
final drive: Belt
Driveline: CVT automatic speed variator
Exhaust system: Euro 3
Chassis, suspension, brakes and wheels
Frame type: Steel tube
Front suspension: Telescopic fork with hydraulic damping
Rear suspension: Single spring with pre-load hydraulic damper
Front tyre dimensions: 120/70-12
Rear tyre dimensions: 120/70-12
Front brakes: Single disc
Front brakes diameter: 220 mm (8.7 inches)
Rear brakes: Single disc
Rear brakes diameter: 140 mm (5.5 inches)
Physical measures and capacities
Weight incl. oil, gas, etc: 113.0 kg (249.1 pounds)
Fuel capacity: 7.50 litres (1.98 gallons)
Yamaha aerox100
- Type :
- Displacement :
- Max power :
- Max torque :
- Starter system :
- Lubrication :
- Carburation :
- Fuel tank capacity :
- Transmission :
- Ignition :
Air-cooled two-stroke single
101cc
5.5 KW @ 6800 rpm
8.8 Nm @ 4500 rpm
Electric and kick
Auto lube
TK
7 litres
Automatic, V-belt
CDI
- Overall length :
- Overall width :
- Overall height :
- Seat height :
- Wheelbase :
- Min. ground clearance :
- Dry weight :
- Front suspension :
- Rear suspension :
- Front brake :
- Rear brake :
- Front tyre :
- Rear tyre : 1746mm
690mm
1170mm
828mm
1259mm
146mm
87.5kg
Hydraulic telescopic fork
Swingarm with hydraulic single shock
190mm disc
Drum 130 mm
130/60-13
140/60-13
- High-specification sport commuter scooter
- High-performance 100cc 2-stroke engine
- Full-sized chassis
- Long, well-padded dual seat for two-up comfort
- Large diameter 13-inch wheels
- Powerful 190mm diameter drilled front disc
- Analog instrument panel
Yamaha aerox100
- Type :
- Displacement :
- Max power :
- Max torque :
- Starter system :
- Lubrication :
- Carburation :
- Transmission :
- Ignition :
101cc
5.5 KW @ 6800 rpm
8.8 Nm @ 4500 rpm
Electric and kick
Auto lube
TK
7 litres
Automatic, V-belt
CDI
- Overall length :
- Overall width :
- Overall height :
- Seat height :
- Wheelbase :
- Dry weight :
- Rear suspension :
- Front brake :
- Rear brake :
- Front tyre :
690mm
1170mm
828mm
1259mm
146mm
87.5kg
190mm disc
Drum 130 mm
130/60-13
140/60-13
Well yeah, if the deals as good as done, but I'll throw 2 more equations onto the table, incase it isn't, first being the Peugeot Speedfight 100 liquid cooled, and second the Aprilia SR125 di-tech, also liquid cooled, both good scooters, more scope to play about with the Aprilia, modding wise,the Speedfight maybe a Malossi 120 kit, primary and secondary gearing up kits, bigger 21mm carb, both easy to get parts for, and with the liquid cooled aspect, you can travel that bit further with them.
My ten penneth anyroad. ;)
not a fan of playing with performance as you change one part then you need to change 1000 other parts never ending cycle. think the piaggio typhoon125 should be fast enough to get me out of trouble and etc
Right then thats one rhetorical question sorted then ;)
