No lights
1979 XS 750 SF. None of the lights work and I have very little time to work on bike. Hoping someone could point me in the right direction to save some "investigative" time. Thanks much :o
Is the bike running?
sounds like a blown fuse, or bad earth, if it is the fuse and it blows again you need to inspect the wiring in more detail,
pull your connectors though and give a spray with some contact cleaner ,or wd40, a mate of mine couldnt get his main beamn and dip to work the other day pulled the connector and gave it a good spray hey presto all good
