December 28, 200421 yr Ive already asked this once but no one helped so Ill try again. I have heard that the gear selector spring can break so I have just put a new one in but the new one I put in is thiner with less winds is this the wrong spring please help ta jason
December 31, 200421 yr Moderator Not sure about thinner? ......but less winds will make it a bit tighter, which might not be a bad thing if you're talking about the recoil spring for the ratchet mechanism inside the cases?
January 18, 200521 yr Author yes i am talking about the recoil springs it is the length as the one in there but thinner and has less coils so im not sure if its right or not? Not sure about thinner? ......but less winds will make it a bit tighter, which might not be a bad thing if you're talking about the recoil spring for the ratchet mechanism inside the cases?
January 18, 200521 yr Moderator With what you've described, that spring seems like it might be a bit weak?
