tez73 Posted July 15, 2011 Posted July 15, 2011 hi i am fitting new sprockets and chain but when i undo the 4 nuts holding the rear sprocket they are turning freely but not coming off at all, if anyone has done this before and knows what to do would be grateful? cheers, terry.
Moderator Airhead Posted July 15, 2011 Moderator Posted July 15, 2011 hi i am fitting new sprockets and chain but when i undo the 4 nuts holding the rear sprocket they are turning freely but not coming off at all, if anyone has done this before and knows what to do would be grateful? cheers, terry. are the studs not moving Terry? sounds like the nuts have stripped try grasping them with a vice grip (mole grip) and pull as you turn anti-clock
2 Wheels Posted July 15, 2011 Posted July 15, 2011 Well Terry,,,,,,whats happening,,,,,,,,,,what did ya try Dude
tez73 Posted July 15, 2011 Author Posted July 15, 2011 are the studs not moving Terry? sounds like the nuts have stripped try grasping them with a vice grip (mole grip) and pull as you turn anti-clock hi mate, no i dont think so, there are black oval plastic parts on the back of the sprocket that the nuts are going into, do they need to be held with a spanner? also is it best to remove nut with wheel and c clip on? will try the grips tomorrow. many thanks for reply, terry.
2 Wheels Posted July 15, 2011 Posted July 15, 2011 Aye Terry. Pull of the black plastic things,,,,,,,,hold the nuts with a spanner,,,,,,,,,put another spanner on the other side, (bolt side),,,,,,,then loosen. You could loosen them before ya take wheel off then fully take them out when wheel is off the bike. Best of luck
Moderator Airhead Posted July 15, 2011 Moderator Posted July 15, 2011 yeah the black plastic things may just be caps to cover the bolt heads...we dont really know as we cant see a picture
tez73 Posted July 15, 2011 Author Posted July 15, 2011 yeah the black plastic things may just be caps to cover the bolt heads...we dont really know as we cant see a picture hi mate, they are covering the bolt thread behind the sprocket the other side to the bolt heads holding sprockets on and are about 10mm wide?
tez73 Posted July 15, 2011 Author Posted July 15, 2011 Aye Terry. Pull of the black plastic things,,,,,,,,hold the nuts with a spanner,,,,,,,,,put another spanner on the other side, (bolt side),,,,,,,then loosen. You could loosen them before ya take wheel off then fully take them out when wheel is off the bike. Best of luck brilliant mate thanks for replies, sounds possible to remove the nuts this way will try it in the morning and let you know, terry.
tez73 Posted July 16, 2011 Author Posted July 16, 2011 brilliant mate thanks for replies, sounds possible to remove the nuts this way will try it in the morning and let you know, terry. the black plastic parts dont come off so bolts must be threaded am going to try putting a flat screwdriver behind nuts and spanner them off now!
Moderator Airhead Posted July 16, 2011 Moderator Posted July 16, 2011 a picture would help tez if you know how...see 'New Members'...'FAQ's'
2 Wheels Posted July 16, 2011 Posted July 16, 2011 Yes,,,,,,,a picture is needed The rear sprocket cant be held on just by bolts going into plastic,,,,,,surley it would never hold
tez73 Posted July 16, 2011 Author Posted July 16, 2011 a picture would help tez if you know how...see 'New Members'...'FAQ's' how do u add pic have looked in help files but it says press choose file button but its not there on my reply page?
Moderator Airhead Posted July 16, 2011 Moderator Posted July 16, 2011 how do u add pic have looked in help files but it says press choose file button but its not there on my reply page? you have to upload the to photobucket, like I said see 'New members'...'FAQ's'
tez73 Posted July 16, 2011 Author Posted July 16, 2011 hi mate sorry to sound like a tit but have changed my settings to attach a photo but wheres the attach photo button? been looking for an hour on help files? !
Moderator Airhead Posted July 16, 2011 Moderator Posted July 16, 2011 Tez you have to open your own photobucket account here Then follow the instructions here to place pictures in the forum It might seem a bit daunting at first but it's not...it's dead easy when you get the hang of it
tez73 Posted July 16, 2011 Author Posted July 16, 2011 Tez you have to open your own photobucket account here http://photobucket.com/ Then follow the instructions here to place pictures in the forum http://www.yamahaclu...sting-pictures/ It might seem a bit daunting at first but it's not...it's dead easy when you get the hang of it cheers for that i had no joy with removing the nuts on the sprocket so i took it to my local tyre shop and they said all 4 bolts were threaded as previous owner put them on to tight, took them an hour to get them off and i need 4 new studs, so i cant use that wheel until they are replaced. fortunatly i had a spare rear wheel so soaked it in lube and took me half an hour to replace them. the plastic oval bits are to grip with a spanner while the nut is removed but they are really flimsy so it is difficult not to break them! seems silly to put them on something where you need a strong fixing. thanks for that link i will still put a picture on later just sounds more difficult than a moon landing when you read the help files!! cheers again for all the help posted, terry
Moderator Airhead Posted July 16, 2011 Moderator Posted July 16, 2011 Good , glad you sorted it Terry
