I am looking for an electronic ignition conversion for a 1974 DT350A. Does anyone Know if someone makes one? Also if the front fender painted silver by the factory or if the fender is molded from silver plastic?
Thank you
Waddy
Hi waddy, you could try rexs speed shop
or you could try finding an ignition set & flywheel for the DT360A bit hard to come by but you never know your luck. Regarding the front mudguard im sure its sprayed silver, heres my DT360A.
Need any other info on them just ask.
TTB
TTB
I have the original front fender ,high mounted [ silver ] in plastic, or the steel low mounted fender in silver, [ uk model] ,
