xvs 650, is my sidestand switch at fault...
getting it ready for mot so i can register my vstar
so cleaned her up, she was bloody dirty
ran it up and put it in gear and she dies, though it might be the cluch sticking as my kwack does but i can roll it around in gear with the clutch and there is no jolt.
just dies like the gear is the kill switch then the starter button does nothing untill its in neutral
on my kwak i would say it was 100% the sidestand switch doing this but i though i would ask if there is anything else on the star that would do it, i may have ridden it alot but i've never pulled it apart at all
plus the switch does move in and out, but only by about 5 or 6 mm then it rests on the braket thing, is it supposed to come right out and stay in contact with the cam shapped bit on the sidestand
sorry for stupid quustions :)
joe
Mine did that when I put too much oil in it once.
Cheapest stuff first - Clean the switch out and check the contacts.
yeah mine is leaking oil cos i over filled it
Overfilling can cause pressure build up and blow seals. Drain the excess off, check levels with the bike level
There's your problem.
As mentioned, get your bike upright and level. Drain oil down to correct level and there you go.
Might take a couple of goes to cycle the excess oil out.
are you saying the fact there is too much oil in it could be whats stopping it working???
Uh... Yes.
In fact, I'm banking on the too much oil DEFINITELY being what's causing the issues.
Lets hope the leaks arent a sign of damage due to overfilling.
2 pieces of sound advice posted so far, both simple to do and possible quick wins
Let us know how you get on
