June 23, 201115 yr Does anybody know if you can buy screws for footpegs on their own? The screw on my right hand footpeg seems to have shaken loose without my knowing. The first I knew of this was when the peg itself came off as I went round a bend!
June 23, 201115 yr What, the two flange-headed bolts that secure the footpeg bracket on? Bolt, Flange, Part No. 90105-102A3? Yeah, you can get them easy. ANY motorcycle parts shop should be able to get them, if they don't already have them in stock. When you get them, tighten them up to 64 Nm (6.4kg or 46.3 ft/lb).
