June 21, 201114 yr Hey... i have a dt125r 2 stroke, having problems with the speedo.. had the speedo cable attached to the speedometre spun the wire and it moves. when attached at both ends took it out to see if it worked and it dosent move an inch?! so is it one end of the cable or something to do with the front wheel connection?.. please help.. thanks
June 21, 201114 yr Moderator Place the bike on a stand, disconnect the cable from the drive unit...spin the wheel and see if the drive rotates.
