Posted June 21, 201114 yr does anybody have or know where i can get a left n/s side panel from (the black plastic one that fits below the exhaust) for 1977 175 enduro
June 21, 201114 yr Hi Col68, They don't seem to appear much on EBay so a wrecker might be your best bet? Gordo
June 22, 201113 yr Hi Col68 You could try () they have supplied me with some hard to get DT twinshock parts in the past,
June 22, 201113 yr If you widen your search on ebay to "worldwide" you will find loads, particularly in asia.
June 23, 201113 yr Moderator have been down all above avenues still no luck Darren it takes time mate, the bike is old and rare now. you have to search long and hard but ebey is no doubt your best bet. is it a 1G1 model? I will keep an eye out too
June 24, 201113 yr Darren it takes time mate, the bike is old and rare now. you have to search long and hard but ebey is no doubt your best bet. is it a 1G1 model? I will keep an eye out too Hi Col68 As a last roll of the dice you could take a plaster cast of another side panel from another DT, then you could use that cast as a die to make a fiberglass one using fast a fast glass kit, you will have to use some release compound so the finished fiberglass casting will come free from the mould, I have made some other plastic bits and bobs like this, I have done this before to make model boat hulls. (http://www.cstsales.com/tutorials/fiberglass_mold.pdf) Just found these!!! http://cgi.ebay.com/ebaymotors/LEFT-SIDE-COVER-1975-YAMAHA-DT175-_W0QQcmdZViewItemQQhashZitem1e63dbd997QQitemZ130524371351QQptZMotorcyclesQ5fPartsQ5fAccessories http://cgi.ebay.com/ebaymotors/NEW-Yamaha-DT100-DT175-Side-Cover-LR-_W0QQcmdZViewItemQQhashZitem415a086341QQitemZ280683373377QQptZMotorcyclesQ5fPartsQ5fAccessories http://cgi.ebay.com/ebaymotors/Yamaha-1974-76-DT175-Side-Cover-_W0QQcmdZViewItemQQhashZitem27b8718657QQitemZ170598172247QQptZMotorcyclesQ5fPartsQ5fAccessories
June 24, 201113 yr That looks like an earlier side cover. I couldn't see the '77 175 on the parts listing I use but the 250 and 100 didn't match that as far as I could see. I have one from the '74 dt though so if it is the same I'm sure I could make a mould. Have you been able to find an image of the cover that you need? Gordo
June 24, 201113 yr does anybody have or know where i can get a left n/s side panel from (the black plastic one that fits below the exhaust) for 1977 175 enduro Is it the 1G1 twinshock model, or the MX monoshock model?
June 24, 201113 yr Moderator Is it the 1G1 twinshock model, or the MX monoshock model? Can't be the monoshock that has the exhaust behind the panel.
June 27, 201113 yr Author ureka spoke to dave at redrose hes got one and is sending it today thanks to all
