help dt175 enduro
col68
This post is 4899 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi Col68,
They don't seem to appear much on EBay so a wrecker might be your best bet?
Gordo
Link to comment
Share on other sites
If you widen your search on ebay to "worldwide" you will find loads, particularly in asia.
Link to comment
Darren it takes time mate, the bike is old and rare now. you have to search long and hard but ebey is no doubt your best bet.
is it a 1G1 model? I will keep an eye out too
Hi Col68
As a last roll of the dice you could take a plaster cast of another side panel from another DT, then you could use that cast as a die to make a fiberglass one using fast a fast glass kit, you will have to use some release compound so the finished fiberglass casting will come free from the mould,
I have made some other plastic bits and bobs like this, I have done this before to make model boat hulls.
(http://www.cstsales.com/tutorials/fiberglass_mold.pdf)
Just found these!!!
http://cgi.ebay.com/ebaymotors/LEFT-SIDE-COVER-1975-YAMAHA-DT175-_W0QQcmdZViewItemQQhashZitem1e63dbd997QQitemZ130524371351QQptZMotorcyclesQ5fPartsQ5fAccessories
http://cgi.ebay.com/ebaymotors/NEW-Yamaha-DT100-DT175-Side-Cover-LR-_W0QQcmdZViewItemQQhashZitem415a086341QQitemZ280683373377QQptZMotorcyclesQ5fPartsQ5fAccessories
http://cgi.ebay.com/ebaymotors/Yamaha-1974-76-DT175-Side-Cover-_W0QQcmdZViewItemQQhashZitem27b8718657QQitemZ170598172247QQptZMotorcyclesQ5fPartsQ5fAccessories
Link to comment
That looks like an earlier side cover. I couldn't see the '77 175 on the parts listing I use but the 250 and 100 didn't match that as far as I could see.
I have one from the '74 dt though so if it is the same I'm sure I could make a mould.
Have you been able to find an image of the cover that you need?
Gordo
Link to comment
does anybody have or know where i can get a left n/s side panel from (the black plastic one that fits below the exhaust) for 1977 175 enduro
Is it the 1G1 twinshock model, or the MX monoshock model?
Link to comment
Can't be the monoshock that has the exhaust behind the panel.
Link to comment
  • Recently Browsing
