June 19, 201114 yr Hi, just bought some custom handlebar grips for my xvs1300,can anybody tell me how to get the standard ones off without damaging them ta.
June 19, 201114 yr Hi, just bought some custom handlebar grips for my xvs1300,can anybody tell me how to get the standard ones off without damaging them ta. hi if you can, get a thin bladed screwdriver under them,lift them and squirt water and washing up liquid mixture underneath them,few twists to spread liquid and work of th bars. cheers mark.
June 19, 201114 yr Only left (clutch) is glued. Remove as above... if you would like pictures look HERE (it shows how to change handlebars but includes removing grips) Which one's did you get? I swapped my handlebars to RSTD handlebars and put on Kury ISO grips. Graham
June 19, 201114 yr I found a very easy way to remove grip. Take a thin stiff piece of wire and bend a crank shape in the end. Insert wire down grip and then turn wire, it will work round the bar and release the grip all the way round with no damage at all.
June 21, 201114 yr sneak into the bedroom and pinch your lass's hairdryer, gently warm the grip up and use a twisting movement , the heat will melt the glue
June 22, 201114 yr If it's anything like my 650, the right grip will also be glued, but to the throttle sleeve not the bar. Be careful when prising this one off in case you crack the sleeve.
June 22, 201114 yr If it's anything like my 650, the right grip will also be glued, but to the throttle sleeve not the bar. Be careful when prising this one off in case you crack the sleeve. I think you're right - just remembered the Kury came with it's own throttle sleeve...
