Posted June 15, 201113 yr Hello I would like to know the position of the petrol dial for on -reserve and also prime. the bike was running ok and then just stopped it was on the side stand at the time,if i try to start it wont go so i think i need to prime the carbs.
June 15, 201113 yr On is straight down at the 6 oclock position, reserve is straight up at 12 oclock and prime is at the 3 oclock position. Remember prime is only used to fill the carbs. In normal use you leave the tap in the ON or Reserve positions.
