June 14, 201115 yr Hi, Hope someone can help as i'm running out of ideas! I have a '99 thundercat which starts up fine on all four cylinders. After around 5 minutes or after the bikes warms up I lose cylinder 1 and it mis-fires. I have checked and replaced the following ignition coil 1 & 4 replaced Plugs gapped and changed New Air filter Carb stripped and needle cleaned (head 1). Could it possibly be ECU/CDI Any ideas would be much appreciated. Thanks, Dave
