born to ride Posted June 12, 2011 Share Posted June 12, 2011 hi guys am having a problem with my clutch sticking on my dragstar just wondering any ideas how i sort this problem out Link to comment Share on other sites More sharing options...
neversaydie Posted June 12, 2011 Share Posted June 12, 2011 hi guys am having a problem with my clutch sticking on my dragstar just wondering any ideas how i sort this problem out Oil level ok? When did you last change the oil and filter? Freeplay adjusted as per the manual? Link to comment Share on other sites More sharing options...
born to ride Posted June 12, 2011 Author Share Posted June 12, 2011 Oil level ok? When did you last change the oil and filter? Freeplay adjusted as per the manual? i only did a full service on the bike about 2 weeks ago and ajusted the clutch cable and the clutch is still sticking Link to comment Share on other sites More sharing options...
Moderator Airhead Posted June 12, 2011 Moderator Share Posted June 12, 2011 can you describe in more detail "clutch sticking" Link to comment Share on other sites More sharing options...
born to ride Posted June 13, 2011 Author Share Posted June 13, 2011 can you describe in more detail "clutch sticking" it sticks in when you put it in gear and doesn't come back out Link to comment Share on other sites More sharing options...
neversaydie Posted June 13, 2011 Share Posted June 13, 2011 i only did a full service on the bike about 2 weeks ago and ajusted the clutch cable and the clutch is still sticking Was it "sticking" before the service? Is the clutch lever returning to correct position? Is the inner cable free to move in the outer? Watch what happens at the bottom end of the cable on the engine, does the lever move back and forth? Is the spring still on? What type of oil did you use? Link to comment Share on other sites More sharing options...
