clutch sticking on my dragstar 125
hi guys am having a problem with my clutch sticking on my dragstar just wondering any ideas how i sort this problem out
Oil level ok?
When did you last change the oil and filter?
Freeplay adjusted as per the manual?
Oil level ok?
i only did a full service on the bike about 2 weeks ago
and ajusted the clutch cable and the clutch is still sticking
can you describe in more detail "clutch sticking"
it sticks in when you put it in gear and doesn't come back out
Was it "sticking" before the service?
Is the clutch lever returning to correct position?
Is the inner cable free to move in the outer?
Watch what happens at the bottom end of the cable on the engine, does the lever move back and forth? Is the spring still on?
What type of oil did you use?
