Posted June 10, 201113 yr Just building an SR250 Cafe here are some pics http://www.barkingmadspeedshop.com/2011/02/1980-sr-250-cafe-bike_21.html Just moving to the exhaust any ideas?
June 10, 201113 yr Just building an SR250 Cafe here are some pics http://www.barkingmadspeedshop.com/2011/02/1980-sr-250-cafe-bike_21.html Just moving to the exhaust any ideas? Sweet mate, bet that hammer causes a bit of discomfort,mind is that the tool kit for it?
June 10, 201113 yr Moderator I used to have 1 of those SR's....... great little bike! Yours is progressing nicely mate.
June 10, 201113 yr Author The hammer stopped the seat from flopping off backwards. I expect it will be a fun little bike. we toyed with a larger motor but was not sure the frame would take it. The frame has had all of the tabs etc removed, I weighed the frame and its 19 pounds the stock one that I have with all tabs still on is 27 pounds.
June 13, 201113 yr Author Soda blasted the motor today.. http://www.barkingmadspeedshop.com/2011/06/soda-blsating-motor-stage-1.html
June 29, 201113 yr Author Few updates! http://www.barkingmadspeedshop.com/2011/06/tank-is-stripped.html http://www.barkingmadspeedshop.com/2011/06/built-or-better-said-split-chopped.html http://www.barkingmadspeedshop.com/2011/06/first-batch-back-from-painters-and.html
July 6, 201113 yr Author A few updates things will go quickly now.. http://www.barkingmadspeedshop.com/2011/07/its-alive-or-at-least-roller.html http://www.barkingmadspeedshop.com/2011/07/hubs-are-about-done.html
July 6, 201113 yr Author Ohhh shiney, I like shiney it looks good lots of work tho, Almost should have painted them just almost tho...
July 9, 201113 yr Author Today... Rear wheel is laced up and ready to be trued Rear sets are bolted up Wiring is being put on and lengthened where needed One side cover is polished All of the shift assembly and brake assembly have been cleaned and polished up Picked up the tank Polished spoke nipples Painted some stuff Picked up a bunch of parts, heat shrink, connectors, replacement brake switches, another bunch of nuts and bolts and some other odds and ends...
July 11, 201113 yr Author Triples and speedo mounted! http://www.barkingmadspeedshop.com/2011/07/triples-spedo-and-headlight-mounted.html
July 17, 201113 yr Author In the final stretch! http://www.barkingmadspeedshop.com/2011/07/down-to-final-bits.html
July 18, 201113 yr Author Better all done! http://www.barkingmadspeedshop.com/2011/07/shes-all-good-to-go.html
July 18, 201113 yr Moderator Better all done! http://www.barkingmadspeedshop.com/2011/07/shes-all-good-to-go.html yea, now we want a cool video to see the bike in action my pequeno amigo
