Hi Guys,
I recently purchased a set of XV 125 pannier racks from Ebay, these are the genuine article, but they have no fitting instructions so i am lost as to how they fix.
I think i may have worked out that they bolt through the mudguard and then the pillion seat but if i place them, the holes line up but the indicators are in the way.
It seems that in order to use them that the indicators need to be moved.
Anyone out there got similar and can light the way?
I dont mind moving the indicators to further around the mudguard, but this does mean i will need to extend the wiring as well. My only issue is, i must be missing something!!!
Any help would be appreciated.
See those rings at the back of the top rail, where it curves round?
That is where you relocate the indicators to.
You will likely need longer wires, but do check beforehand. There's sometimes quite a bit, as I found when I relocated my Drag indicators.
I expect your wires will have those little knobbed connectors shaped like a little willy, that fit into a socket inside a clear plastic sleeve.
Should be an easy enough switch-out - Just wire in short extension wires and remember which wires go where. Wrap a small tab of masking tape around each wire end and write notes on it - ie A to A, B to B etc...
Might also be worth running the new wiring through a conduit to help keep the water out.
Shout if you need further advice ;)
Hi,
Thanks for all your help.
I have moved the indicators and added new wires, all fitted now.
Thanks again.
I love this site!!!
Propper Job!!!!!
Nice big saddlebags too, eh!!
