yamaha dt 125 cluth problems
hi every 1 ive just had me engine rebuilt and i started it everything was fine then i went to put in into gear and it stalled , so i striped it all down and checked it had all plates and push rod bearing and all is there ,i disconnected my clutch cable and put my bike into gear and pushed it but the bike isnt trying to bump start like it should the clutch is stil spinning it like am pulling in the clutch lever any idears ...regaurds ryan
You've got to give the lad credit for being trying :)
Ryan " you can"t have put it back properly,,, when engine case is off , touch the plates, if they"re loose, then there in wrong, ;)
