June 4, 201115 yr hi having trouble getting spark on my 68 dt1 250 have power when kicking over on pos side of coil but not at the plug also power on neg side any help thanks steve.
June 4, 201115 yr Moderator Check there is a low resistance through the ignition coil primary to ground. Check the points are opening just before TDC
