Indicator Problem
Hi Guys, I just brought 99 R6. It is really good condition. The only problem I have is that the indicator on the left side flashes fast then slow. Both of the bulbs are working.(so a blown bulb isnt the issue). Basicly I turn the left indicator on then they flash fast for a few seconds then flash normal speed then fast again for a few secs. Any ideas what is causing this?
Might seem obvious but check that all of the bulbs are the same wattage/voltage
