Posted December 7, 200420 yr hey guys i hope u can help me its just i am trying to get a pw 50 going compression is good spark plug is good and new ignition coil. I removed the oil and run pre mix but the bugger douesnt wanna start or run the carbie is clean. i check the spark wile on start and goodspark but when on run it doesnt spark is this ment to be. is there some thing i am missing.
December 8, 200420 yr Moderator Got one of those myself Gigs........they have some type of weird switching in the ignition, where you have to flip that handlebar swith to RUN after it's started :? .....something to do with transferring the spark :?: I'd like to get a hold of a factory service manual for these bikes, & figure out how to bypass that switch all together. :wink:
December 9, 200420 yr Author thnks for that any way also i saw on ebay a power up grade for these little bikes how can i get the most out of em
September 27, 200718 yr Got one of those myself Gigs........they have some type of weird switching in the ignition, where you have to flip that handlebar swith to RUN after it's started :? .....something to do with transferring the spark :?: I'd like to get a hold of a factory service manual for these bikes, & figure out how to bypass that switch all together. :wink: I just saw this old posting and I could show you how to bypass the off-run-start switch if you like. Cheers Ferg :
