rattle rattle topend or bottom end ???
rob.patton
This post is 4754 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Pull the clutch in...is it still there?
If it's not the clutch, as OG suggested, have a butchers at the powervalve, see if its catching, my mates was making that sort of noise, after he'd messed about, trying to set his manual powervalve.
ill have a look 2morz think it is the powervalve what if it is dose that mean i have fucked my pistion n powervalve ??????
I certainly hope not, I ended up buying the bike off him. :rolleyes:
You b4stard :o
ha ha ha, very good!! :blink:
i played around with the power valve 2day no difference :( i have never rebuild a dt b4 though :wacko: i did the old trick put a long screwdriver to my ear and different parts of the engine its defo the top end, i think its the Small End Bearing i never changed it then i did the top end rebuild I KNOW SILLY ME :blush: that or the piston has gone where the power valve has hit it :pissed-off: ill have a look 2morz as i never got around to it 2day ended up painting the frame :sleeping:
yep still there !!!
have you tried the screwdriver trick? i know it sounds daft but it works.
get a long screwdriver and put the pointy end on a part of the engine, now put your ear on the handle . (you can listen through the screwdriver!) its a great trick for finding noises coming from the engine, try different places on the engine to locate exactly where it is coming from.
soz....you posted b4 i did lol
Edited by Paulwhite
should b ok then lol
:blink: :blink:
Who's bike is it now eh ???
