Posted May 28, 201114 yr The days of fast bikes has passed! My Dragstar is now just a summer option and now out of mothballs for 2011. Problem - The fuel pours out of the overflow pipe, I have stripped the tank etc away and blown out the carbs twice, rebuilt and she runs but still pours Liquid Gold? Help/ Cruisermel
May 28, 201114 yr Moderator carb float / needle valve may have jammed, try giving the carb a tap with the wooden shank of a hammer...sometimes it frees it. Otherwise you will have to investigate further.
May 29, 201114 yr Author carb float / needle valve may have jammed, try giving the carb a tap with the wooden shank of a hammer...sometimes it frees it. Otherwise you will have to investigate further.
