carb p***ing it out !!!!!
hi i got a dt 125 r as a project all going well top end rebuilt runs well apart from now its started leaking fuel out the over flows on the carb i striped it down and it seems all ok can any1 help please :D
Sounds like your float needle, or float isn't sitting properly, carefully take off carb, undo the 3 screws at the bottom of your carb so you get into the float chamber, check needle or the bar/pin that holds the float in place then, carefully put back on carb, as tilting it can make the bar/pin come out.
